integration with Zabbix via Ansible build -- pdagent key validation issue
We are building Zabbix v6 with Ansible on Linux, integrating PD in the Zabbix alerting.
The RPM package pdagent is failing to validate the GPG signature. Giving this error:
Signature not supported. Hash algorithm SHA1 not available .\r\n\r\n{“failed”: true, “msg”: “Failed to validate GPG signature for pdagent-1.7.3-1.noarch”
The Ask: Is there a more recent key for GPG signature available for this package? Signing with SHA1 algorthm is deprecated…right?
hello,
do you resolved this issue? I have the same problem with nagios integration when i try to install pdagent on a “CentOS Stream release 9”
thank you
Hi! It seems a deprecation issue explained here. Meanwhile, a good workaround could be allowing the deprecated crypto policy (scroll down the article and follow the “I still to install SHA-1 signed packages!” section).
Hope it helps!
